First BMW, and it's been on the road (slightly) longer than I have.
huskcummerbund
Barstow-ish, CA., USA
Z3 1.9L 5MT
How's it going? I recently moved from Honolulu to the middle of the desert outside of Barstow, and I've been on two wheels exclusively for the last three years. Actually just traded my Honda CB500X for a brand new Transalp (and it absolutely rips). A couple weeks ago, I bought my father-in-law's 1998 Z3 1.9 that he bought new while stationed in Germany and had it shipped from Massachusetts out to California. He was very reluctant to let it go, but his clutch knee just couldn't take it anymore and selling it to me at least kept his favorite vehicle in the family. He upgraded the suspension and other parts, mostly with AC Schnitzer parts I believe, and had it tuned by Dinan. This is definitely not like pretty much any other vehicle I've owned, save for the third pedal, and I'm already finding "BMW things" that I need to wrap my head around.
The first headache was just getting the electric soft-top back up. I'm not proud to admit that I spent a solid 10 minutes trying to reason my way through it before I had to go find the manual. Turns out you have to lower both windows AND hold the brake... Also, it regularly pops a check-engine light but I wasn't able to get much information about what the actual code is (yet). It has an OBDII port under the dash, but it looks like it also has a different, round, OBD port under the hood on the passenger side of the engine. What's that about? What's the difference between the two? What would be a good code reader that is known to work well with this little roadster?
Also, I'm already finding things that I want to tweak and parts that could use a replacement. Where could I find a good wiring diagram for the car, and are there any reputable OEM quality parts suppliers for interior and exterior trim pieces and the like?
Finally, are there common failure points I should keep an eye out for? I think I saw something about some sort of solenoids in the intake that are a common issue, and something about the rear subframe or something that can crack over time.
Any enlightenment you guys can send my way would be appreciated.
Thank you,
Chase
ChrisD
Vale of Evesham
M44
Thank you,
Chase
For a good, cheap OBDII scanner, take a look here:
You’re lucky on a number of fronts. Firstly, to connect to the engine controller, you don’t need to worry about the round 20pin diagnostic socket in the engine bay. That’s a BMW diagnostic socket and unless you have the right tools, training and reference material it’s not going to be very useful. Just go straight into your OBDII socket - older cars in the UK don’t have this hence the use of an adapter for the 20pin BMW connector.
Also, with your engine, you don’t need to worry about intake solenoids (VANOS) or, unless the vehicle has had a very hard life, the rear subframe cracking (trunk spot welds).
Enjoy your new car and welcome to this forum.
Delk
Hemsby Norfolk
Z3 3.0T
Picture?
You need an adaptor and use the round plug near the engine. Dont ask me why but thats the way they made it. Adaptors are common and not very expensive.
Massachusetts and Hawaii will not be good for rust so keep an eye on the inner sills and jacking points. Removing the outer sills at some point and rust proofing the inners would be my recommendation.
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Roadster
Welcome :welcome: to the forum.
huskcummerbund
Z3 1.9L 5MT
Picture?
No photos yet. Haven't even had much time to mess with it in the daylight thanks to the time change. Eventually though.
Yeah, that's one of the few spots that visibly needs some love on the car. Fortunately, the car was never in Hawaii. We just moved from HI to CA and THEN I bought the car. The car wasn't driven all that much in the winter in Mass, and was fairly well cared for, but yeah, there's a bit of rust on the outer sills and probably some more on the inside that I'll need to address. I was pretty impressed when I found out the outer sills are removable, so in the next few weekends I'll probably take a closer look. It's currently OEM silver, but I do want to either paint or wrap it in something a bit more interesting to my eye. A dark green with a bit of sparkle to it is the front runner at the moment.
Also, sick! Thank you very much for the diagrams doc.
huskcummerbund
Z3 1.9L 5MT
Thank you for the info! I'll have to double-check when I get home that the car does, indeed, have the OBDII port under the steering column. It seems like for that couple of years some did and some didn't, and I haven't seen it for myself yet. If I do, then pretty much any reputable OBDII scanner should be good then, it sounds like.
I'm glad to hear that the smaller motor means I've likely lucked out on having to deal with some of the issues seen in other cars. That's a relief. I do hear a bit if a rattle in the rear end somewhere that I'll need to investigate though, but could just be normal at this age. Fortunately, I live on a military installation with a DIY car care center, so I've got access to a lift. I might need to make some ramps though.
Mazza
Bognor Regis
We like pictures and progress threads so look forward to reading about your cars updates !!! :thumbsup:=))
Pontrhydyrun - in Crow Valley
M44 FrankenZed
1998 1.9 likely won't have the obd port inside the car. Mine is an early 99 1.9 and it has the a flap over the hole where the obd port is on later cars but mine's empty. I think the obd port under the dash just appeared mid 99. But, I've been lead to believe that the obd under the dash just does engine diagnostics. The round one under the hood is where you get everything.
FLZ_Boy
Texas
Z3 1.9L
Given it's age, I would look at:
1. Coolant hoses and plastic pipings ( front of engine, rear of head, side block of engine - buried near the center of the engine)
2. All air hoses, most likely the fuel and idle hoses have deteriorated to some extent. Most likely a power steering hose is leaking, probably the one that connects from the PS resevior to PS unit.
3. Oil leaks, most likely valve cover and oil pan.
4. Clean the idle air valve, fairly easy.
5. Check suspension bushings and rear sub frame bushings.
There are two suppliers for BMW aftermarket and OEM parta for us peeps in the States: FCP Euro and ECS Tuning.
huskcummerbund
Z3 1.9L 5MT
Awesome! Thank you very much.
2.2 Sport Individual
Hi Chase and :welcome: to the forum from me too in Stafford, England.
elevensies
North Lincolnshire
roadster 2.8 widebody
howdee from lincolnshire England, welcome aboard
We like pictures, especially unusual cars from around the globe, as the car came out of Germany, i would almost certainly look at the inner sills, and possibly the rear calipers and dust protectors, as these do rot away and rattle in the disc.
I take it your father was airforce? where was he stationed? (off topic sorry)
elevensies
North Lincolnshire
Mark, all Z3s were made in Spartanburg, SC, USA. ;)
hey buddy, the post said '' I bought my father-in-law's 1998 Z3 1.9 that he bought new while stationed in Germany ''
so as it was originally a german car, but yes made in usa..
huskcummerbund
Z3 1.9L 5MT
Thank you. I still haven't taken any beauty shots yet. I'll have to take a look in those areas when I get it in the lift. It failed smog, likely due to the 15 year old AC Schnitzer exhaust system he put on. I just need to add a spacer for the downstream O2 sensor to slow down the reading just a little bit.
He was actually US Army, same with his wife, and they lived in several areas. Kaiserslautern, Heidelberg, and one other that I can't remember. I've been there a few times too, but only short, also Army related trips. The EU tag actually came with it, but I can't put it on while I'm living in an area that requires front tags. Maybe if I can't figure out the smog thing I'll just register it in Oklahoma instead. They don't require a smog check or a front plate.
EDIT: Turns out he just put on a cat-back system, so it's a 27 year old OEM cat. Yeah, that would do it.
huskcummerbund
Z3 1.9L 5MT
Figures. The moment I get the OBDII system to calm down about the downstream O2 sensor and finish all 8 of the I/M monitors, the pilot bearing decided to die on my way to work. So, instead of finishing registration, I have to yank the transmission. If I can even make it home first, 45 miles away.
huskcummerbund
Z3 1.9L 5MT
Update: Two months and ~$3000 worth of tools and parts later, this is where I am in the project:
You guys wanted a beauty shot, right? lol
Let me put this up front: I've never replaced a clutch before, but I like a challenge.
Most of that two months was just waiting on tools, like that car lift or burning off weekends doing things with my wife instead of working on the car.
I managed to get the transmission out after two days of fighting with it, two weekends apart. I figured out the hard way why the starter has to be unbolted prior to transmission removal... because physics. I have already cussed myself sufficiently for that blunder. To my eye, all of the components involved actually don't look damaged or at the end of their service lives. It almost looks like maybe the slave cylinder was pushing the pivot fork and throw-out bearing too far forward when the clutch pedal was fully pressed and the bearing just got a little cockeyed at the end of the sleeve it rides on and jammed up. Is that a thing that can happen?
The question I have, and the selfish reason that prompted me to do an update post, is regarding the throw-out bearing and clutch assembly adjustment. I know on a lot of vehicles you have to add or remove shims from the throw-out bearing after making somewhat precise measurements of the data points involved, but every video and guide I've been able to find so far for this car seems to omit any mention of that process. So... is that not necessary? Is the system of components between the clutch pedal and the pressure plate just self-adjusting? To be clear, I am fairly certain the clutch pressure plate that was installed was not one of the self-adjusting types. I believe this is the kit that was installed: https://www.fcpeuro.com/products/bmw-clutch-kit-318i-318is-318ti-z3-valeo-52161203
Unfortunately I ordered the wrong clutch kit the first time (before I got the transmission off and knew what was in there... like an idiot) and it doesn't mate up with the aftermarket flywheel my FIL installed a decade ago (going by MFG Dates on the outgoing parts), so now I'm waiting on some feedback from FCPEuro regarding exactly which Valeo "Flywheel Conversion Service Kit" they recommend based on the photos I provided. It would be nice if I could shave a couple hundred bucks off by not having to buy a replacement for a perfectly good flywheel.
