Soft close boot fault
rishannp
Hello Dan
I have just fixed mine, The car boot was twerking up and down trying to close.
This will happen to all e89s at some point, and BMW will try and sell you a full very expensive mechanism when it is just not needed
It's an easy and no cost fix
I have sent you all the photos of how I did mine, in a PM.
I would have put it as a sticky but I don't bother anymore, because there are plenty that challenge my own 'actual experience', in favour of other 'experts/guru's' who, let's say, have obviously more 'valued opinions' on here of what is definitely wrong.....
Because of this, I have chosen to adopt the 'my ball' syndrome now... and I can decide who I play with. :thumbsup:
those 'experts' can advise otherwise, and if you think 'does he mean me?...... then I probably do..=))
Hi mate,
Same thing has happened to my Z4, its 2:20 in the morning and safe to say I am tired🥲. Hoping you could send me the fix!
Thanks,
Rishan
RobbiZ4
Germany
E89 sDrive30i
Have a look at this thread and get it translated by translate.google if required:
Theship2024
Hello Dan
Hello mate,
Experiencing the same issue with my Z4, soft close won’t engage anymore. Any chance you could send me the photos to help me try and fix it.
Thanks 🙏🏻
Tim
You Tube Vid
From Z4 Forum.com
Spent a couple of hours addressing this today. First off I checked the boot light connector. 12v present but no continuity to earth - very likely the left-hand soft close loom identified by others on this thread. Stripped the boot lid down, stripped the insulation back and...bingo!
Black wire was broken, green came apart with the lightest of touches, blue was good albeit exposed:
Right-hand loom didn't have any broken wires (yet) but was deteriorating:
Soldered up the left-hand wires, insulated with heat shrink and relooomed with fabric tape:
On the right-hand side I just insulated the exposed wire with electrical tape and reloomed:
Put it all back together, worked a treat
:thumbsup:
Took a couple of videos from inside the boot of each latch - you can see how the loom moves when the boot opens or closes.
LH latch:
Imagez4 boot left by Ian Conuel, on Flickr
RH latch:
ImageIMG_1265 by Ian Conuel, on Flickr
  • Like
Reactions: B21
Theship2024
You Tube Vid
From Z4 Forum.com
:thumbsup:
LH latch:
RH latch:
Thank you so much. This was great help.
I’ve dismantled it all, and looks like it’s already had an attempted repair by a previous owner.
I’ve found that the blue wire is completely cut right at the white loom. Any tips on how to fix this, how to get the white loom off to get the remaining wire out?
Thanks
Thanks
You are welcome thanks to the Z4 forum though. 😉
Thanks
To be honest the Z4 forum is the best place to ask for e89s they have a dedicated area for them and lots of great help and advice from its members.
GarryO
Hello Dan
Hi Gookah
I have the same problem with my 2012 Z4. Would you be kind enough to provide the solution, so that I can get this irritating fault fixed, please? Many thanks. I don't know if it makes any difference but mine is a UK, right-hand drive version.
Garry
Hi Gookah
Garry
There is link already posted #25
Wilks
Hello Dan
Hello Gookah, can you send me your fix please. I have the same problem
Aress
Hello Dan
Hello, I'm having the exact same issue. Can you please share the recommended solution with me? Thank you.
